"bad" word
yuriy
posted: 14
Denver,CO,USA
1subject: "bad" wordPromote 0 Bookmark 02010-01-24quote
Hello there ,
I use gcin ver. 1.4.5
My default input method is  pinyin.gtab
when I type cao4 I get  操 but should be 肏
and gcin switched in simplified mode.
so is it a bug ?
2subject: Promote 0 Bookmark 02010-01-24quote
肏 is not defined in the table.
Why don't you use ctrl-alt-6「詞音」? It also support pinyin keyboard。
BTW, 肏 is f*** 大笑
yuriy
posted: 14
Denver,CO,USA
3subject: Promote 0 Bookmark 02010-01-24quote
I  guess Ctrl + Alt + 6 support "taiwanese" pinyin the problem is ... I dont know Taiwan pinyin and I use stardard keyboard .
Or   「詞音may support China pinyin too ? If yes .. than how to?
4subject: Promote 0 Bookmark 02010-01-25quote
The keyboard can be set by gcin-setup. You can also
echo pinyin > ~/.gcin/config/phonetic-keyboard
And restart gcin.
