enPV editor
Add a shadow to a color-filled polygon
1subject: Add a shadow to a color-filled polygonPromote 0 Bookmark 02018-02-17quote
How to add a shadow to a color-filled polygon.
  1. While the filled polygon is selected, tap the second-level menu→Polygon selection→Copy polygon selection
  2. Poly select→shadow/gradient
  3. Adjust the postion. Lower the shadow, under the color-filled polygon. You can change the color of the shadow (e.g. blue) if you don't like the grey shadow.
 產生陰影步驟
edited: 6
enPV editor
