cht台灣個人winlin其他網路上不錯的文章
[無效] 加速Openoffice的方法?
1subject: [無效] 加速Openoffice的方法?Promote 0 Bookmark 02008-03-26quote
事實上我覺得效果不明顯
http://tuxtraining.com/2008/03/04/speed-up-start-time-for-openofficeorg/
Go to any Open Office application (Writer, Calc, Impress, Math, Draw, Base) and then proceed to the Tools Menu. At the bottom of that menu select Optoins.
Under the OpenOffice.org heading, select Memory
Now change these settings:
Undo:
Number of steps = 25
Graphics Cache
Use for OpenOffice.org = 30 MB
Memory per Object = 2.0 MB
Remove from memory after 00:05 hh:mm
Cache for inserted Objects
Number of Object = 15
OpenOffice.org Quickstarter (check this box)
