enComputerLilyTerm
LilyTerm 0.8.7 is released, many bugs fixed!
Tetralet
posted: 255
promoted: 35
bookmarked: 13
1subject: LilyTerm 0.8.7 is released, many bugs fixed!Promote 0 Bookmark 02008-04-26quote
2008/4/25 (0.8.7) (Source Code) (Debian Lenny Package) (Ubuntu Gutsy Package)
  • FIX:
    • Now LilyTerm works fine with kwin. (It is the window manager of KDE).
      Thanks to swyear and caleb for report this bug.
    • Better compatibility with some xorg build in video modules when rgba is enabled.
      If you still encounter trouble, like black screen, transparent or colorless text, please insure the following setting:
    • Option "XAANoOffscreenPixmaps"
      is in your /etc/X11/xorg.conf.
    • Better compatibility when the font rendering / theme changed.
    • Use <Ctrl><`> (NOT <Ctrl><~>) to disable function keys.
      Thanks to BV1AL for report this bug.
    • `screen_width' is rename to `column' in rcfile.
    • `screen_height' is rename to `row' in rcfile.
  • New Feature:
    • If you're using a composited window manager, rgba will be enabled by default.
      You may use use_rgba = 0 to trun off True Opacity if you're using a composited window manager but you don't want to enable it in LilyTerm.
      You may use use_rgba = 1 to turn on True Opacity if you're using xcompmgr, which can't be resolved by gdk_screen_get_rgba_colormap().
    • you may use show_resize_menu = 0 to disable [Increase windowsize], [Increase window size], [Reset to default font/size] and [Reset to system font/size] in menu.
    • Now [Change Font] in right click menu will change the font of all tabs.
    • Now [Transparent Background] and [Background Saturation] will apply to all tabs.
    • New menu item: [Reset to default font/size] will reset every tab to user default font and size.
    • New menu item: [Reset to system font/size] will reset every tab to system default font (Monospace 12) and size (80x24).
  • DROP:
    • Menu item: [Change Font for current tab] is obsoleted.
enComputerLilyTerm
