enComputerLilyTerm
LilyTerm 0.9.6 is released, Supports 'VTE_CJK_WIDTH' and separate environ!
Tetralet
posted: 255
promoted: 35
bookmarked: 13
1subject: LilyTerm 0.9.6 is released, Supports 'VTE_CJK_WIDTH' and separate environ!Promote 0 Bookmark 02008-07-30quote
2008/7/30 (0.9.6)
For GJK users:
If your vte is >= 0.16.14 (Debian Lenny), and you want to enable VTE_CJK_WIDTH, Please make sure that you had applied the patch on Bug 542795 .
  • FIX:
    • Better behavior when run with such as LC_ALL=zh_TW (not zh_TW.Big5).
      Thanks Balázs Hámorszky for reporting this bug.
    • The label of GtkNotebook won't be on-focus-able when tab number = 2.
      Thanks PCMan for fixing this bug.
    • Better compatibility with hyperlink.
  • New Feature:
    • Applied updated German translation.
      VERY THANKS to Mario Blättermann.
    • Switch VTE_CJK_WIDTH = wide/narrow via right click menu.
    • Better hyperlink support. You may specify the VTE_CJK_WIDTH and environment used for the hyperlink via edit the profile.
    • Every LilyTerm window may use separate environment in single process mode.
    • <Ctrl><`> will disable mouse right click menu too.
enComputerLilyTerm
